Coolscan LS-9000 con Nikonscan e Vista 64bit
Per chi è interessato il Nikon Coolscan LS-9000 ora funziona con il suo software Nikonscan sotto Windows Vista 64bit. Se a qualcuno interessa descrivo tutta la procedura.
Inviato: 14/5/2009 19:28
Re: Coolscan LS-9000 con Nikonscan e Vista 64bit
Sono tutt'orecchi
Inviato: 14/5/2009 20:03
Tank
Tessera C.F.A.O. n° 48
foto......
Allora:
1) Immagino avrai Vuescan per farlo funzionare. Vai nella cartella Vuescan, salva il file scanners.inf in una nuova cartella che ti servirà  dopo. Apri il file scanners, cancella il contenuto e modificalo incollando il testo qui sotto:
;========================= Begin of scanners.inf ===============================
; scanners.inf -- Windows Still Image Setup File
[Version]
Signature="$CHICAGO$"
Class=Image
ClassGUID={6bdd1fc6-810f-11d0-bec7-08002be2092f}
Provider=%Provider%
DriverVer=1/1/2009,1.0
[Manufacturer]
%Mfg%=Models,ntamd64
[Models]
; USB scanners
"Nikon LS-40" = USBScanner,USB\Vid_04b0&Pid_4000
"Nikon LS-50" = USBScanner,USB\Vid_04b0&Pid_4001
"Nikon LS-5000" = USBScanner,USB\Vid_04b0&Pid_4002
"Nikon LS-10" = SCSIScanner,SCSI\ScannerNikon___COOLSCAN________
"Nikon LS-20" = SCSIScanner,SCSI\ScannerNIKON___COOLSCAN_II_____
"Nikon LS-1000" = SCSIScanner,SCSI\ScannerNIKON___LS-1000_________
"Nikon LS-30" = SCSIScanner,SCSI\ScannerNIKON___COOLSCANIII_____
"Nikon LS-2000" = SCSIScanner,SCSI\ScannerNIKON___LS-2000_________
"SCSI Scanner" = SCSIScanner,GenScanner
"SCSI Scanner" = SCSIScanner,SCSI\GenScanner
; Firewire scanners
"Firewire Scanner" = SBP2Scanner,SBP2\GenScanner
;---------------- Duplicated from [Models]
[Models.ntamd64]
; USB scanners
; Other SCSI Scanners (type 6)
; Firewire scanners
"Nikon SUPER COOLSCAN 8000 ED" = SBP2Scanner_NIKON,SBP2\NIKON___&LS-8000_ED______&CMDSETID104D8
"Nikon SUPER COOLSCAN 9000 ED" = SBP2Scanner_NIKON,SBP2\NIKON___&LS-9000_ED______&CMDSETID104D8
;---------------- USBScanner -------------------------
[USBScanner]
Include=sti.inf
Needs=STI.USBSection
SubClass=StillImage
DeviceType=1
DeviceSubType=1
Capabilities=0
[USBScanner.Services]
Include=sti.inf
Needs=STI.USBSection.Services
;---------------- SCSIScanner ------------------------
[SCSIScanner]
Include=sti.inf
Needs=STI.SCSISection
SubClass=StillImage
DeviceType=1
DeviceSubType=1
Capabilities=0
[SCSIScanner.Services]
Include=sti.inf
Needs=STI.SCSISection.Services
;---------------- SBP2Scanner ------------------------
[SBP2Scanner]
Include=sti.inf
Needs=STI.SBP2Section
SubClass=StillImage
DeviceType=1
DeviceSubType=2
Capabilities=0
[SBP2Scanner_NIKON]
Include=sti.inf
SubClass=StillImage
DeviceType=1
DeviceSubType=2
Capabilities=0
AddReg=NK1394SCN.AddReg
CopyFiles=NK1394SCN.CopyUSDFiles
[SBP2Scanner.Services]
Include=sti.inf
Needs=STI.SBP2Section.Services
[SBP2Scanner_NIKON.Services]
Include=sti.inf
[NK1394SCN.AddReg]
HKR,,HardwareConfig,1,2
HKR,,DevLoader,,*NTKERN
HKR,,NTMPDriver,,"scsiscan.sys"
HKR,DeviceData,ICMProfile,1,0,0
HKR,,USDClass,,"{07C71AC0-FA90-11d3-B409-00C04F87578E}"
HKCR,CLSID\{07C71AC0-FA90-11d3-B409-00C04F87578E},,,"Nikon STI USD"
HKCR,CLSID\{07C71AC0-FA90-11d3-B409-00C04F87578E}\InProcServer32,,,%11%\NKSCNUSD.DLL
HKCR,CLSID\{07C71AC0-FA90-11d3-B409-00C04F87578E}\InProcServer32,ThreadingModel,,"Both"
[SourceDisksNames]
1=%DiskName%,,
[SourceDisksFiles]
NKSCNUSD.dll=1
[DestinationDirs]
NK1394SCN.CopyUSDFiles=11
[NK1394SCN.CopyUSDFiles]
NKSCNUSD.dll,,,32
[Strings]
Provider="steelchn@gmail.com"
Mfg="DIY Software"
DiskName="Nikon Scan 4 CD-ROM"
;========================= End of scanners.inf ===============================
2) Disinstalla ogni precendente driver dello scanner sotto Pannello di controllo-Sistema-Gestione dispositivi.
Vai in Prorietà  e poi nella cartella Driver-Disintalla e poi spunta rimuovi anche il software driver. Fai poi un reboot per iniziare una installazione pulita.
3) Installa Nikonscan 4.0.3, poi copia il file NKScnUSD.dll dalla cartella C:\Program Files (x86)\Common Files\Nikon\Driver\Scan1394 nella cartella che avevi prima creato dove hai inserito il file scanners.inf di Vuescan modificato.
4)Apri di nuovo Gestione dispositivi e clicca sullo scanner LS-9000 e poi seleziona aggiorna driver. Seleziona manualmente come percorso la cartella che avevi prima creato dove ci sono i due file scanners.inf e NKScnUSD.dll
5) Clicca sempre ok a tutte le richieste e scegli sempre Installa.
A fine installazione driver lo dovresti vedere installato correttamente in Gestione dispositivi e quando apri Nikonscan lo riconosce.
Poi se vuoi puoi reistallare Vuescan e così puoi usare entrambi
Inviato: 14/5/2009 20:34
Grazie Gianluke. Lo proverà in questi giorni.
Inviato: 15/5/2009 10:40
Tank
foto......
Gianluke, hai mica fatto qualche prova con Win7 64?
Ho installato la RC di Win7 64 Ultimate (quella che scadrà  a Giugno 2010 insomma) e non mi sembra terribile come Vista (che era petulante e lento a rispondere), anche se l'occupazione di RAM è pazzesca (1 GB senza aprire niente).
Mi chiedo però che compatibilità  reale avrà  con le applicazioni a 32 e 64 bit esistenti.
Tipo appunto Vuescan, Photoshop CS4 64 etc.
Inviato: 16/5/2009 10:01
no nessuna prova. Mi bastano tutti i problemi che ho avuto nei primi 12 mesi di Vista per i drivere a 64 bit
Non voglio più fare il pioniere...
Ma tu l'hai installato parallelamente a Vista sullo stesso PC? O l'hai installato su un secondo PC?
Puà darsi che tutto che funziona con Vista 64 bit funzioni anche lì...
Inviato: 20/5/2009 11:03
Io non ho installato Vista; Win7-64 è sullo stesso PC di WinXP-32, su una partizione separata (il boot loader di Win7 permette di far partire anche XP).
Proverà pian piano ad aggiungere software nelle prossime settimane: le periferiche principali comunque funzionano tutte (video, audio, rete etc.); temevo un po' per l'accelerazione 3D (ho una NVidia 8800) e l'audio (Creative X-Fi) ma sono usciti i driver nativi, va tutto OK.
Inviato: 20/5/2009 11:18
Devo confessarvi che ... stamane stanco di tribolare con Wista ho deciso di ... "scancellarlo" dall'hd.
Uffa nonnepotevopiùuuuuuuuu.
Sto pensando seriamente di usare definitivamente l'ultima release di Ubuntu (molto molto matura) ed usare solamente xp32 solo per la camera chiara (cs4).
Voi che ne pensate?
Fer tienici informati su Win7
Saluti
Inviato: 20/5/2009 18:54
Tank
foto......
Vi aggiorno su Win7RC-64: Vuescan funziona correttamente e pilota correttamente quantomeno il mio Minolta 5400, utilizzando i driver appunto di Vuescan (non ci sono driver nativi Win64 per il Minolta).
Inviato: 22/5/2009 19:50
E cs4 come va?
Inviato: 22/5/2009 19:53
Tank
foto......
Ancora non ce l'ho.
Inviato: 22/5/2009 21:47
salve a tutti,
sono nuovo da queste parti.
Lavoro esclusiavamente su pellicola ma ho deciso di convertire tutti i miei negativi.
Ho acquistato un nikon 9000 collegato al pc con win7 64 ed "ovviamente" non lo riconosce.
ho letto la procedura per vista, qualcuno ha sperimentato la stessa cosa con win7?
grazie mille
antonio
Inviato: 22/12/2009 13:52
non sono sicuro per la versione a 64 bit, ma pochissimi giorni fa (il 14 Dicembre per l'esattezza) è stata rilasciata la versione 8.5.40 del software VueScan compatibile con Win 7.
Dal momento che c'è la possibilità  di scaricare ed utilizzare una versione di prova prima dell'acquisto, non ti resta che verificare.
Inviato: 22/12/2009 16:33
Grazie luciano,
scusami mi sono espresso male io: intendevo utilizzare nikon scan 4 con coolscan 9000 e win7.
ho provato la versione demo di vscan e funziona perfettamente, volevo sapere se è possibile utilizzare in qualche modo SCAN 4.
grazie ancora
antonio
Inviato: 22/12/2009 17:14
Aggiornamento:
tank ha scritto:
E cs4 come va?
Decisamente bene! I 64 bit vengono ben sfruttati, ho assegnato 5.5 GB a Photoshop (su 8 totali).
Naturalmente ho preso i plugin dedicati a 64 bit (PTLens, FocalBlade e NeatImage).
Inviato: 22/12/2009 21:07
pistzone ha scritto:
Grazie luciano,
grazie ancora
antonio
Ciao Antonio,
ho fatto l'aggiornamento a W7 64bit in questi giorni.
Per far funzionare correttamente Nikon Scan 4.0.3 ho dovuto installare i driver di VueScan.
La sequenza è questa:
1) Si installa Nikon Scan 4.0.3 (il sw non tova lo scanner)
2) Si installa VueScan rispondendo SI quando chiede se si vuole installare i driver.
A questo punto funziona correttamente anche Nikon Scan.
Inviato: 27/12/2009 15:44
Ciao Fabio,
auguri di buon 2010!!
ho provato la procedura ma non va.
Vuescan funziona perfettamente ma nikon scan non riconosce il scanner.
durante l'istallazione di nikon scan devo scollegare lo scanner? ci sono altri passaggi particolari da tenere in considerazione?
grazie
antonio
Inviato: 1/1/2010 21:18
Grazie Antonio, ricambio gli auguri.
Credo che l’unica accortezza da adottare sia quella di installare prima NikonScan e poi VueScan con i suoi driver, in modo che questi ultimi sovrascrivano quelli di NikonScan; io almeno ho fatto così e tutto funziona.
Non so però se il tipo di scanner utilizzato puà determinare qualche differenza; io uso NikonScan v4.0.3 con un LS-50.
Inviato: 2/1/2010 22:03
Sono riuscito a far riconoscere il nikon coolscan 9000ED da nikonscan 4.0.3 su win7 64bit utilizzando la procedura suggerita da GIANLUKE.
grazie per i suggerimenti.
antonio
Inviato: 5/1/2010 0:58
90 utente(i) online
(78 utente(i) in Forum)Iscritti: 1
Ospiti: 89
luciano, altro...
